1994 Nissan 300ZX I have a Check Engine light on. Car runs
SCOTTWALLACE
  • 1994 NISSAN 300ZX
  • 6 CYL
  • 10,900 MILES
My Question is: For the last 2 weeks the Check Engine light has stayed on and will not go off. I put the OBD1 Computer in Mode 1 and Mode 2. I taped the flashes of the Computer with my camcorder and there are 5 long flashes and 1 short flash. This 1994 300zx is Not a TURBO, it also has California Emissions, Auto trans, AC, PW, PS, CRUISE CONT, Stereo. I recently Replaced the battery with a Nissan OEM battery. I have been running Shell 91 Octane gasoline, but before the problem started I put in some 89 Octane gasoline. The car runs very ROUGH. Could the car have bad gasoline or just too low of Octane.(91 is the highest you can get in Las Vegas, Nevada). Or could one of the Fuel Injectors be bad?
I have pinpointed the flashes on the computer to be a code# 51 which is fuel injector circuit.
Monday, October 26th, 2009 AT 3:03 AM
Z32BRYAN
  • 16 POSTS
Run only 91 octane, our manual says 96 only but nowhere here sells anything higher than 91 except for vp but im not paying 7 dollars a gallon for 101 octane
91 is safe, dont run anything other than 91 unless its higher octane
Friday, April 9th, 2010 AT 2:21 PM
