Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Nissan
300ZX
Warning Lights
Overdrive Light
1990 Nissan 300ZX
1990 NISSAN 300ZX
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
HAYDEAN175
MEMBER
1 POST
i have a 1990 300zx, automatic tranmisson will not go into overdrive you can push the button on the stick on or off,overdrive light stays on
Feb 3, 2010 at 1:16 PM
KHLOW2008
Experienced Mechanic
Hi haydean175,
Thank you for the donation.
Does the OD Off light goes off when ignition is turned ON without the engine being started?
I suspect you have a faulty OD switch.
Feb 5, 2010 at 12:55 AM
Add image or video
Ask a new question
Engine won't start
Engine overheating
