1985 Nissan 300ZX car wont start
YETO17
  • 1985 NISSAN 300ZX
  • 6 CYL
  • 180,000 MILES
The car was park in a lot for over 7 years and was never turn on the car cranks but won't start
Tuesday, January 20th, 2009 AT 4:57 PM
Do below and see what happens
Get a starting fluid or ether and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Tuesday, January 20th, 2009 AT 5:00 PM
