1989 Nissan 240SX Won't Start
BURGERCOW
I own a 89' 240sx, I got back from my deployment and the car started fine and ran really good for about 2 mins, then it died and it just started running really rough when I could get it running, like it just wouldn't die sometimes, it would be just running at about 100 rpms and just make wierd noises. And if I push on the gas it'll die out or send air back out through the intake. Any answers on a way to get it at least out of the lot?
Oct 24, 2007 at 9:02 AM
  • 75,988 POSTS
Replace the O2 sensor and inspect the plug/wire/injector on No.1 cyl. There's no danger involved here- The problem is the computer cannot adjust the fuel accurately due to no signal from the O2 sensor.
If the engine fails to go into closed loop when the O2 sensor reaches operating temperature, or drops out of closed loop because the O2 sensor signal is lost, the engine will run too rich causing an increase in fuel consumption and emissions.
Oct 24, 2007 at 9:32 AM
MBOOGIE
thank you very much.
another question, is it safe to drive for now until i get it repaired? or do you recommend not to drive the car?
thank you
Oct 25, 2007 at 8:04 AM
  • 75,988 POSTS
Yes-the only thing is gonna happen is the fuel consumption gonna increase.
Oct 25, 2007 at 5:48 PM
Suggested Repair
Replace the oxygen sensor and inspect the No. 1 cylinder spark plug, wire, and injector. The car can be driven, but fuel use may increase until the O2 sensor signal is restored.
Conversation Summary
A 1989 Nissan 240SX started after storage, ran briefly, then died and ran very roughly at low RPM, with backfiring through the intake when the throttle was opened. The expert advised replacing the O2 sensor and inspecting the No. 1 plug, wire, and injector, explaining that a missing O2 signal can keep the engine from closed-loop fuel control and cause a rich condition. Driving was considered acceptable, with higher fuel consumption expected until repaired.
