1996 Nissan 240SX Head Gasket Leak Fix
JBLACKSHER12
I drive a 1996 Nissian 240SX, about 100K miles on it. It is leaking coolant through a head gasket, according to a local Firestone auto shop. I was wondering what the appropirate cost would be, should I choose to have it repaired or replaced.
May 2, 2007 at 5:51 AM
2CARPRO JACK
  • 11,533 POSTS
SInce that is a chain driven engine it will be a little more, expect 700.00 up. Ther is no repairing a head gasket, it must be replaced or further engine damage could ensue.Be sure the head is pressure tested and surfaced before being re-installed
May 2, 2007 at 9:04 AM
Suggested Repair
Replace the head gasket rather than attempting a repair. Because this is a chain-driven engine, expect about $700 or more. Pressure-test and surface the cylinder head before reinstalling it to avoid further engine damage.
Conversation Summary
The owner of a 1996 Nissan 240SX with about 100,000 miles was told by a shop that coolant is leaking through the head gasket and asked about repair versus replacement cost. The expert said a head gasket cannot be repaired and must be replaced, or further engine damage may occur. Because the engine is chain-driven, the job may cost $700 or more, and the head should be pressure-tested and surfaced before reinstallation.
