2002 Nissan Sentra No Heat Overheating
MAD6920
  • 5 POSTS
i have a 2002 nissan gxe milage is 56,793 that has an overheating and no heat problem when driving i have no heat and vehicle overheats less than an hour on road ive changed thermostat flushed heater core and refilled raidiator and i get heat for a few minutes then it blows cold air then temp. gauge shoots up to red then overheats please help!!!!!!!!!
Jan 2, 2007 at 11:58 AM
  • 75,988 POSTS
Remove the Stat and see what happens to your overheating problem
Do you hear the cooling fan? when engine is idling?
Jan 2, 2007 at 12:58 PM
MAD6920
  • 5 POSTS
what is the stat?? and yes the fan does come on when overheating but not when idle
Jan 2, 2007 at 11:52 PM
MAD6920
  • 5 POSTS
if u mean the thermostat i will do that and see what happens but i do know it works i put it into a pot and boiled it and it did open
Jan 3, 2007 at 12:01 AM
MAD6920
  • 5 POSTS
i did take out the thermostat and filled the raidiator drove the car i do get heat now and i notice the temp gauge stays in the cold will that cause a problem and if not is it ok to leave it that way during the summer too???
Jan 3, 2007 at 11:17 AM
  • 75,988 POSTS
Its your choice-Remember the computer has to read the temperature from the coolant temperature sensor for other purposes such as fuel delivery and tranny shifting/overdrive etc. Best bet is just get another T-Stat with the correct Temperature for your model.
The final decision is yours-Good Luck
Jan 3, 2007 at 11:38 AM
MAD6920
  • 5 POSTS
i have just one more question i was reading some of the other posts and i seen somewhere about a heater control valve does my car have one and if so were is it??
oh and thanks for the help :D
Jan 3, 2007 at 6:10 PM
  • 75,988 POSTS
Should be on the heater hose before it goes in the heatercore.
Jan 3, 2007 at 8:27 PM
Suggested Repair
Install a new thermostat with the correct opening temperature for this model rather than leaving it out. The coolant temperature reading is needed for fuel delivery and transmission shifting. If equipped, the heater control valve is on the heater hose before the heater core.
Conversation Summary
A 2002 Nissan GXE overheated and lost cabin heat after a thermostat replacement, heater-core flush, and radiator refill. Heat returned briefly, then the gauge climbed to red. The cooling fan ran only when overheating, not at idle. With the thermostat removed, heat returned but the gauge stayed cold. The expert advised fitting a correctly rated thermostat because the computer uses coolant temperature for fuel delivery and transmission control, and said a heater control valve, if present, is on the heater hose before the heater core.
