1997 Nissan 240SX wont start
120,000 MILES • 4 CYL • FWD • AUTOMATIC
IMWOODY2000
the car ran fine a week ago was parked and sat for a week then wouldn't start, plugged in the computer and got error code P1441, which is some cut valve thing....would that stop it from starting...what should i look for??
Apr 22, 2009 at 1:29 AM
  • 75,988 POSTS
Get helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Apr 24, 2009 at 3:44 PM
