1991 Nissan 240SX engine starting
OLRUSTY
  • 1991 NISSAN 240SX
  • 4 CYL
  • MANUAL
  • 187,000 MILES
My Sons car wiill not start without squirting gas or ether into the air intake-air filter- hot or cold. After squirting with gas into the intake the engine starts, runs well and strong. So far I have replaced the entire dist, dist cap, rotor, plug wires. Fuel regulator, plugs, We have checked fuel pressure before and after fuel filter-Its good according to the book. I, ve checcked every injector by hooking to the fuel rail pressured with gas via two hoses, and the injectors all squirt gas as they should.
Thursday, August 6th, 2009 AT 9:02 PM
KHLOW2008
  • 41,814 POSTS
Hi olrusty,
Thank you for the donation.
The symptoms indicates it is a fuel related problem and based on what you have tried to get it started, I would suggest checking the Mass Air Flow and Engine Coolant Temperature sensor.
Did you try to retrieve for trouble codes?
Did the MIL show while driving?
Sunday, August 9th, 2009 AT 9:06 AM
