1991 Nissan 240SX Engine starting
1991 NISSAN 240SX
UCONN
Electrical problem
1991 Nissan 240SX 4 cyl Two Wheel Drive Automatic
I turn the key and get nothing. Battery checks good and the cables are clean and tight at the battery, starter and ground. I have 12+ volts at the starter. Dash lights come on when the key is turned.
Aug 3, 2008 at 3:34 AM
A240SX
  • 27 POSTS
Probably your clutch safety switch is missing the gromet on the pedal so when you press the clutch it isnt flipping the switch... i taped a penny over the hole so i wouldnt have to worry about replacing a gromet after it wears out
Aug 4, 2008 at 12:45 AM
A240SX
  • 27 POSTS
correction... sorry didnt see u had an automatic...
Aug 4, 2008 at 12:46 AM
AIRMAN2007
[quote:193445e7ce="uconn"]Electrical problem
I turn the key and get nothing. Battery checks good and the cables are clean and tight at the battery, starter and ground. I have 12+ volts at the starter. Dash lights come on when the key is turned.[/quote:193445e7ce]
Hey....i had the SAME problem one night...it doesnt turn over....and you can hear the relays when you attempt to turn over....i dont know if its the same problem i had...but i took the ignition switch outta the back of the lock cylinder....and you just turn the switch with a screw driver and it starts. Lemme know if that works for ya. If it is that then you'll need a new switch and or lock cylinder
Oct 11, 2008 at 12:24 PM
