Replaced fuel pump due to fuel gauge no longer working and the fact it had sat without use for two years. Old pump was nasty and the screen was destroyed. Gauge arm was completely corroded. Car started with old pump but only when it wanted to. Also changed spark plugs and wires with a new battery/terminals/oil change prior to replacement of fuel pump. It started up and ran fine on day one. Day two it did not start right away just sputter and shut off, did that three times and started up. I made it three blocks at 25 mph and went to give it gas to go up a small hill and the RPM's got to 4,500 but mph only went to 27. Replaced pump. Now cranks no start.
Oct 22, 2018 at 4:36 PM
