This is a 4 step process.
1 - tighten bolts to 27 ft/lbs\
2 - re-tighten the bolts to the same 27 ft/lbs
3 - turn each head bolt an additional 90 degrees
4 - turn each bolt an additional 90 degrees.
You will need a 10mm bi-hexagon wrench. Additionally, there is a specific sequence in which the bolts needs tightened. However, it isn't showing up in my online manual.
Oct 16, 2014 at 12:47 PM
