Engine not starting
152,000 MILES • 4.5L • V8 • 4WD • AUTOMATIC
JAMESCO707
Floor boards were soaked and wires were corroded. spliced wires together started up and drove fine. next day went to store and it won’t start; one wire came disconnected reconnected and no power to ignition everything else lights up, turn key nothing PSM light is on and service engine. why do I not have power? code read out P0030 02 sensor and heat circuit. I’m puzzled.
Jan 9, 2019 at 9:24 AM
DOCFIXIT
  • 18,828 POSTS
Was car in flood? does starter operate? Have you made any voltage checks?
Jan 11, 2019 at 4:48 AM
JAMESCO707
Rain water backed up and flooded floor boards. it ran fine until the wire broke now no power to ignition. what can it be?
Jan 12, 2019 at 3:51 AM
  • 55,743 POSTS
Did you reconnect the wire? can you take a picture of it and upload it here? Also, is the security light flashing? Please let me know.
Jan 14, 2019 at 4:55 AM
DOCFIXIT
  • 18,828 POSTS
Hi 707, go with Ken a picture would help. also can you provide battery voltage? Is there power to main fuse box? Any information will help.
Jan 15, 2019 at 4:02 AM
