White smoke coming out exhaust
175,000 MILES • 1.1L • 6 CYL • 2WD • AUTOMATIC
CANDACE2028
I was stuck kept reving engine to get out. Ever since there has been a knock worse when I press on the gas. Than now there is white smoke from bottom of engine and white smoke coming out exhaust.
Please why could it be?
Jul 23, 2017 at 11:07 AM
STEVE W.
  • 15,418 POSTS
White smoke usually denotes that it is burning coolant. The knock along with it suggests the engine is dying in a rapid fashion from a bad bearing or connecting rod. It will just get worse until it fails completely, which likely will not be very long.
Here is a guide so you can confirm the failure:
I would take it in and get it checked but I suspect you will need some major work or a replacement engine.
Jul 23, 2017 at 11:52 AM
CANDACE2028
Jul 23, 2017 at 10:08 PM
  • 55,766 POSTS
Cheers, Ken
Jul 24, 2017 at 9:15 AM
