Need Help ASAP
222,000 MILES • 4 CYL • 4WD • AUTOMATIC
MELLOWE
I have had a new radiator replaced in my Subaru Impreza 2000 model. I am having problems when the motor car get hot it push the water out of the over flow pipe and back into the reserved tank. I've had my dad have a look he thought it was the thermistor on the bottom of the engine but it works fine. Just wondering if you would have any idea to what it wrong with my car?
Dec 25, 2015 at 5:46 PM
WRENCHTECH
  • 20,758 POSTS
A little bit of overflow into the reserve is normal. It draws it back inb when cooled but if it is excessive you may have head gasket damage from the previous overheating when the radiator first failed.
Dec 25, 2015 at 11:13 PM
MELLOWE
It empty's it all
Jan 4, 2016 at 3:28 PM
