1998 Subaru Impreza over heating
SWANSEA1966
Engine Cooling problem
1998 Subaru Impreza All Wheel Drive Manual
hi i have a 2litre turbo and it is overheating, i've changed the theormostat and header tank but it is still overheating any ideas? also it is leaking oil from the rocker cover gasket could this cause it to over heat? thanks.
Mar 19, 2009 at 11:01 AM
  • 75,988 POSTS
If you're losing oil the engine tends to get hotter due to friction and can cause the engine to overheat.Your best is to get it block and pressure tested to find the problem and fix the valve cover leak.
Mar 19, 2009 at 11:18 AM
SWANSEA1966
thank for your info very helpfull
Mar 21, 2009 at 1:49 AM
