Brake, gas pedal, and steering wheel locked up after accidentally driving on to a medium
2005 SATURN ION
150,000 MILES
AYOOITSMICKIE
I was driving my car and accidentally ran on to a medium going maybe twenty five mph, but was able to turn off of it really quickly. I decided to start heading home and my car started rattling and humming. After about ten minutes my car, brake and gas pedal locked up and also my steering wheel. I was at an intersection so I put my car in park and tried turning off the car. The car then stopped immediately, made another rattling noise and basically shutdown. I can turn my car back on now. Any idea what was damaged?
Feb 4, 2018 at 12:17 PM
SATURNTECH9
  • 30,869 POSTS
Have you looked underneath the car yet? It sounds like you knocked a hole in your oil pan and lost all your oil in your engine.
Feb 4, 2018 at 3:03 PM
AYOOITSMICKIE
I did not seem to be leaking any fluids when we moved the car, but the car will not turn back on. I can even turn the key all the way. Any other ideas?
Feb 4, 2018 at 3:06 PM
SATURNTECH9
  • 30,869 POSTS
Have you checked your oil level to see if it reads on the dipstick? Also, will the engine crank and no start or no crank no start? Are all the dash lights brightly lit? Or does it act like the battery is drained? Have you checked the coolant level made sure the drive belt is still on the engine?
Feb 4, 2018 at 3:10 PM
AYOOITSMICKIE
No crank no start at all. All my lights and battery related things (windows, etc) work still. And I have not checked my drive belt yet.
Feb 4, 2018 at 3:13 PM
SATURNTECH9
  • 30,869 POSTS
Does your starter make a loud click like it is trying to turn the engine over but is not?Check the oil and coolant level and your belt.
Feb 4, 2018 at 3:19 PM
AYOOITSMICKIE
That is the exact noise yes. Thanks so much! If either of the three are damaged about how much would each cost?
Feb 4, 2018 at 3:55 PM
SATURNTECH9
  • 30,869 POSTS
If it is what I think it is, you need a engine. It sounds like it has seized up. Let me know what you find and we will go from there.
Feb 4, 2018 at 4:42 PM
  • 55,423 POSTS
You can put a breaker bar on the front of the engine to see if it turns over. The electrical seem weird though. Do the headlights come on?
Feb 5, 2018 at 4:35 AM
