My van won't start , it has no spark
150,000 MILES
PIPERS
My express van 1500 has no spark.
Apr 24, 2013 at 11:26 PM
JDL
  • 16,098 POSTS
I looked at the 5.3L, with coil near plug, check primary voltage at coil, pink wire goes hot with the key on. Use a testlite to check for voltage. Go from there. Here is a guide
Can you check for applicable codes?
Apr 25, 2013 at 12:38 AM
2CP-ARCHIVES
  • 4,540 POSTS
5.7,Chevy/2001 , no spark
Sep 25, 2019 at 11:28 AM (Merged)
JDL
  • 16,098 POSTS
Did you check for primary voltage at ignition coil? How long since a tune-up? Any applicable trouble codes? To check codes, yourself, at the least, you need an obd2 code reader. Your local autostore should have one.
JDL
  • 16,098 POSTS
Just to add, the pink wire at the coil is primary voltage, goes hot with the key on. That is a fused circuit, ecm 1 fuse--20 amp under the hood fuse box.
KEVINKESLER
new coil and module installed cut in and out for a few days (randomly lose spark or fuel and cut back on while still rolling) i can follow a schematic or flowchart but have none available have spark now am going to take to service center for tune-up
  • 75,988 POSTS
You got spark now you need fuel -Check the fuel pressure to rule out the fuel pump/regulator and fuel filter
GUITARZAN1
Hi. I have an Express 1500 Van 5.7 Engine. Every now and then it would not start like it wasn't getting any fire. And then I would wait a day or 2 and i would start. Now it won't start and I took the engine cover off and put a screw driver in a Plug wire to check for Spark I'm getting no spark on the Plugs.
GOt any idea what it might be?
Thanks,
Craig
check the coil, cap and rotor.
HOMER1967
  • 875 POSTS
cap and rotor issues are very common on these vehicles,inspect them very closely and if you do replace them use O.E. ONLY PARTS.trust me on this one
