Will not start, rattling sound
STACYMC1
  • 1998 MERCURY MARQUIS
  • MANUAL
  • 171,000 MILES
I drove my car while it was raining and the windshield wipers were broken. Later when I turned off the car it would not start after the fifth try it started up. When I got home and tried to start it up it made a rattling sound and the car would not start after five tries. The engine light, and battery light popped on.
Monday, June 20th, 2016 AT 4:52 PM
CJ MEDEVAC
  • 11,005 POSTS
Codes are the 1st place to start diagnosing
WELL YOU HAVE ONLY ONE CHECK ENGINE LIGHT
ANY OF MANY POSSIBLE REASONS IT IS ON
IF IT WILL TRAVEL,
TAKE THAT PUPPY OVER TO A POPULAR AUTO PARTS STORE
THEY CAN SCAN FOR CODE, USUALLY THIS IS A FREE SERVICE
HAVE PEN AND PAPER HANDY
YOU WANNA GET THE EXACT CODE NUMBERS, THERE MAY BE MORE THAN ONE (NOT WHAT THEY SAY THEY MEAN/ OR IS WRONG)
THEY MAY BE DEAD ON, BUT IF YOU WANT SOMEONE ELSE TO INTERPRET THEM, THE CODE NUMBERS ARE NEEDED.
EXAMPLE OF A CODE MIGHT BE " P0105" (JUST AN EXAMPLE)
THE CODE WILL BE WHAT THE COMPUTER PICKED UP AS A FAULT, SOME ARE EZ FIXES, OTHERS ARE NOT, BUT ABOVE ALL, THE COMPUTER WILL NOT TELL YOU WHAT TO DO OR CHANGE OUT. ONLY " WHAT HAPPENED" AS A RESULT OF THE GLITCH. THE CODE MUST BE INTERPRETED SO THE PROPER SOLUTION CAN BE FOUND.
SCAN MACHINES START AT ABOUT $50 SHOULD YOU WANT ONE OF YOUR OWN OR IF THE VEHICLE CANNOT DRIVE (SHARE THE COST WITH A FRIEND WHO MIGHT NEED IT LATER!)
RETURN WITH GOOD NEWS OR THE CODES!
THE MEDIC
Monday, June 20th, 2016 AT 5:29 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,363 POSTS
Hi STACY,
It sounds like the battery is weak and needs replacing, here is a guide that will help you.
https://www.2carpros.com/articles/how-to-check-a-car-battery
and if it needs replacing
https://www.2carpros.com/articles/replacing-car-battery
Let me know what you find
Best, Ken
Wednesday, June 22nd, 2016 AT 11:25 AM
