Multiple symptoms
2003 JEEP GRAND CHEROKEE
165,000 MILES • 6 CYL • 4WD • AUTOMATIC
MRS. WEIDMAN
All symptoms came on at once. 1)Remote locks and unlocks jeep, however it no longer flashed the parking lights for unlock or horn sounds when locking.
2) Power windows buttons won't work but the door locks button work.
3) High beams work, but dash console display for high beams no longer works.
4) Compass & Temperature display now only displays directions and dash symbols for temp. ( - - °F)
5) Same ceiling display as compass/temp it has a menu, shows the options but without the info. No miles left for tank of gas. No miles left for service, no average car milage. It displays dashes instead of numbers.
6) The ceiling and dome lights only work with the on/off switch on the column. No longer comes on when the door opens and then slowly fades off once it shuts. They were stuck on until I turned them off.
Feb 4, 2016 at 11:35 AM
WRENCHTECH
  • 20,761 POSTS
Sounds like you may have had a Body Control Module failure. You will need a professional scan tool to diagnose that. Test all your fuses first.
Feb 4, 2016 at 6:16 PM
MRS. WEIDMAN
Thank you! Testing the fuses us what I did first. They were all fine! Sounds like I am not going to be able to do this one myself! I appreciate your time.
Feb 4, 2016 at 9:54 PM
  • 55,202 POSTS
You are welcome please get back to us on what you find
Feb 9, 2016 at 10:26 AM
