Multiple performance issues including hard starting, rough idling, and stalling
155,000 MILES • 2.2L • 4 CYL • FWD • AUTOMATIC
MKEMPER331
I've got some rather severe issues with my Camry that have arisen over the past couple of months. The primary symptoms include:
1. Hard starting. The car will crank for some time before starting, and I usually have to give it some gas to get it going and then keep going. Also, the RPMs will rev up and then drop down a bit, fluctuating back and forth, and then if I don't move the car, the engine will stall out.
2. Rough idling. When I come to a stop at an intersection, the car idles rough and the idle speed will fluctuate. This sometimes gets severe enough that the engine stalls out and has difficulty restarting.
3. Stalling. Touched on in the previous two points, but to expand on it here: The car stalls on occasion when I come to a stop, or after starting the car and then not moving from my parked position. It seems to happen most often when the car is "cold" (cold here being a relative term, since where I live, freezing temperatures do not exist), but has happened when warmed up as well.
4. Hesitation when attempting to accelerate from a stop. When I press the gas, the car will hesitate for a moment, RPMs dropping, before finally catching on and accelerating.
As for potential causes that I don't think are the issue, but might be:
The ignition coil, distributor cap, spark plugs, and battery were all replaced December 2013. One or more of these might potentially have gone bad in the interim time frame, but I don't think they generally fail that quickly. Also, the idle air control valve solenoid was bad and I had to have it replaced, which was just this month. I was hoping the replacement would solve the issue, but it hasn't gone away.
Feb 12, 2015 at 9:53 AM
CADIEMAN
  • 3,544 POSTS
u need to ck. the fuel pressure and the timing. both of these tools can be rented at the parts store and u can google how to ck. them.
Feb 12, 2015 at 3:11 PM
MKEMPER331
Ignition timing is good, had it checked out in December (smog test). I'll check the fuel pressure.
Feb 12, 2015 at 4:29 PM
CADIEMAN
  • 3,544 POSTS
if the car was running ok in december.u will need to recheck it.
Feb 12, 2015 at 9:03 PM
