does not have much power and it drives rough
1988 DODGE LANCER
200,000 MILES • 2.5L • 4 CYL • FWD • AUTOMATIC
  • 98 POSTS
I was running errands the other day, when after my first stop the car was hard to start. I had to put my foot to the gas to get it to run. while driving it didn't have much power and drove real rough. Had the same thing on the second stop. When I got it home the back hatch area was smokey and the carpet over the muffler was melted and the bottom of the car (floor) was blistering hot. The next morning I checked the fluid levels and found all to be good except the oil looked a little thin and smelled of gas. When I started the car it cranked for about three seconds before starting. It does not smoke. Can anyone out there help out?
Sep 15, 2016 at 12:58 AM
HMAC300
  • 48,601 POSTS
check fuel pressure with a gauge auto parts rent it.
.https://www.2carpros.com/articles/how-to-check-fuel-system-pressure-and-regulator
Sep 15, 2016 at 2:20 AM
  • 98 POSTS
I'll do that this weekend as well as putting a scanner on it. I pulled the codes using the key method, and go a code 15 ,speed sensor. And that was al.could this cause my problem?
Sep 16, 2016 at 8:52 AM
HMAC300
  • 48,601 POSTS
if it didn't send correct signal to computer it could cause the problem but I kind of doubt it. also check intake manifold vacuum at idle if 15" or less suspect a partially clogged exhaust either converter or exhaust.
Sep 16, 2016 at 9:09 AM
