noise front of engine
1988 DODGE LANCER
20,000 MILES • 2.5L • 4 CYL • FWD • AUTOMATIC
ALAN54
  • 19 POSTS
While driving today I noticed a noise coming from the front of my engine. I put it in park to go see and the noise stopped. I put on the parking brake and left it in gear (drive) and looked again. The crankshaft pulley seemed to be moving in and out about 1/4 inch. Anyone know what this might be? The crankshaft pulley didn't seem to move when the transmission was in park.
Mar 5, 2016 at 3:05 AM
HMAC300
  • 48,601 POSTS
Check for either a broken bolt holding it on or a broken balancer or a bad thrust bearing in crankshaft.
Mar 5, 2016 at 3:29 AM
ALAN54
  • 19 POSTS
I've checked all the bolts and they are in good shape. I don't have a place to check the balancer right now. And I can't seem to find any mention of a thrust bearing in the crankshaft or a way to check it, Any ideals?
Mar 5, 2016 at 6:50 AM
HMAC300
  • 48,601 POSTS
Remove the belt see if crank will push back, then put a large screwdriver behind the pulley and see if it will go forward a ways. If it moves farther than a couple of thousandths of an inch it's probably the crank bearing. It could be a bent pulley as well.
Mar 5, 2016 at 7:55 AM
