Engine cranks but will not start
2000 MERCEDES BENZ ML320
156,000 MILES • 3.2L • V6 • 4WD • AUTOMATIC
ANGELD1993
I have the vehicle listed above that will not start. I've replaced battery, alternator, starter, spark plugs and wires, EGR valve, crankshaft position sensor, fuel pump and filter system, evap, axillary coolant pump. Plus I replaced all relays and fuses. It still doesn't start. It's trying to crank but will not start. Does anyone know what else it could be?
Mar 11, 2021 at 1:57 AM
There is not much left on the list but we need to find out what we don't have in order to get it to start. You need spark, fuel, air, and compression. Here is a guide that will help with this:
https://youtu.be/dCjmRL3p4Cs
We can assume at that point that we have air and compression as spark and fuel are more common to be the issue.
So let's use starter fluid in the intake to see if it fires. If not, pull a plug and hold it against the block and crank the engine to see if you have spark.
Then we need to find out if the theft system is activated. If it is, that will cut fuel and spark so the engine does not start.
Let's start with this and go from there. Thanks
Mar 12, 2021 at 1:41 AM
ANGELD1993
I put the spark plug tester on my car and barely light up. Could it be the ignition coils?
Mar 21, 2021 at 10:08 PM
Absolutely it can. If you have weak spark then it sounds like the secondary side of the coil is not causing the high voltage spike to generate the needed voltage. I would replace it and retest. Good work.
Mar 22, 2021 at 11:34 AM
