1998 Mitsubishi Mirage Turpentine Smell
MITSUBISHI
KITSY
Everytime i get in my misubishi mirage 98 there is a weird smell like tupintine. it gets better after i drive. it is worse the longer it sits, but there is never any fluid below the car after it is parked any idea? I dont know for sure the engine size and the milage is about 80k
May 6, 2007 at 4:50 PM
  • 75,988 POSTS
[quote:8264f9ed70="kitsy"]Everytime i get in my misubishi mirage 98 there is a weird smell like tupintine. it gets better after i drive. it is worse the longer it sits, but there is never any fluid below the car after it is parked any idea? I dont know for sure the engine size and the milage is about 80k[/quote:8264f9ed70]
You sure you're not smelling the la puu/antifreeze from a leaky heater core.Also better check the radiator coolant level.
May 6, 2007 at 6:37 PM
Suggested Repair
Check the radiator coolant level and inspect for a leaking heater core, which can cause an antifreeze odor that is stronger after the car sits and fades while driving.
Conversation Summary
The owner of a 1998 Mitsubishi Mirage with about 80,000 miles reports a turpentine-like smell that is worse the longer the car sits and improves after driving, with no fluid visible under the parked car. The expert suggests the odor may be antifreeze from a leaking heater core and recommends checking the radiator coolant level.
