2002 Mitsubishi Eclipse Antifreeze Smell
2002 MITSUBISHI
DJHAFNER
  • 8 POSTS
I have 2002 Mits Eclipse GS with 110,000 miles
Just had a brand new radiator and thermostat installed. Now smelling strong fumes of burning antifreeze from under the hood. The fumes are not leaking into the car however. Just a strong smell that radiates from the car after parking.
Plus the temperature gauge will occasionally jump past the middle mark, but then will always come right back down.
What could be the problem? Are these fumes dangerous?
Thank you very much.
Michael
Tucson, AZ
Oct 23, 2006 at 7:39 PM
LEGITIMATE007
  • 5,121 POSTS
well, it may be coolant that spilled on the block and is now burning off. the temp gauge jumping back and forth may be from the engine coolant temp sensor being faulty, or an air pocket in the system. the fumes can be dangerous, but as long as you have some ventilation, you should be fine
Dec 15, 2010 at 10:19 AM
Suggested Repair
Check for coolant spilled on the engine during the radiator and thermostat service that is burning off. Bleed any air pocket from the cooling system and inspect the engine coolant temperature sensor if the gauge still jumps.
Conversation Summary
The owner of a 2002 Mitsubishi Eclipse GS with 110,000 miles reports a strong burning antifreeze smell under the hood after a new radiator and thermostat were installed. The temperature gauge occasionally jumps above the middle mark and then returns. The expert suggests spilled coolant burning off the engine, an air pocket, or a faulty coolant temperature sensor, and notes that the fumes can be hazardous without ventilation.
