2002 Other Mitsubishi Models 2002 Mirage won't start
2002 MITSUBISHI
11,000 MILES • 4 CYL • FWD • AUTOMATIC
ITSSHARIG
My Mirage was running a little rough and hesitating when I tried to start it and finally it just won't start. We've replaced the plugs, wires, fuel filter, distributor cap, and rotor and nothing has help. We also had someone change the fuel pump and computer control relay but no luck. He disconnected the injectors and the car almost started which he never saw before. We're all puzzled and thought it may have something to do with the computer board but we can't locate it. Do you know where the computer curcuit board is located on a 2002 Mirage? Do you think this is the problem or do you have any suggestions?
automatic / 1.5 engine
Oct 25, 2008 at 4:24 AM
TECHNOPRO
  • 45 POSTS
Hi itssharig,
The computer is situated under the center console in front of the gear lever.
Before going to the computer, I would suggest you check the timing, spark at the plugs and fuel.
Let us know how you get on.
Cheers
Oct 26, 2008 at 11:32 PM
