1992 Mitsubishi Eclipse Spark Plugs Fix
MITSUBISHI
JAYCEE74CAT
Hello everyone,
I want to replace the spark plugs of my mitsubishi eclipse 92, and this is my first time to do this. Can someone walk me through how to do this?
Thanks,
jaycee74cat
Aug 10, 2006 at 12:39 PM
BESTBET777
  • 89 POSTS
First get a torque wrench, next pull wires by gripping as close to the plug as possible, next clean around the plugs so dirt does not get into the cylinders, next unscrew plugs, gap new plugs correctly, screw in new plugs using torque wrench set to proper torque, plug wires pack in.
Apr 19, 2007 at 6:05 AM
Suggested Repair
Use a torque wrench. Pull each plug wire by gripping it close to the plug, clean around the plugs so dirt does not enter the cylinders, then remove the old plugs. Gap the new plugs correctly, install them to the proper torque, and reconnect the wires.
Conversation Summary
The owner of a 1992 Mitsubishi Eclipse asked for a first-time walkthrough of spark plug replacement. The expert advised using a torque wrench, removing wires carefully, cleaning around the plugs, gapping the new plugs, installing them to the correct torque, and reconnecting the wires.
