Oil pressure light on
MGNTWO
  • MITSUBISHI
I have a 95 eclipse gs non turbo with a bit of miles, 145,000. The engine locked up and I did a rebuild with new bearings, crank, piston, rings and valves and replaced oil pressure switch. When at idel when the car and oil warms up I lose oil pressure bad, then if I rev it it regains pressure but I have to keep the rpms higher as the engine heats up. Any idea whats causing this? My first guess is oil pump but a mechanic told me he doesnt think its that.
Tuesday, August 21st, 2007 AT 1:06 PM
COSTADELBOY
  • 26 POSTS
I would certainly think it was the oil pump did you check this when you did your rebuild, If not remove the oil sender and fit a oil pressue guage and get the pressure reading other causes worn out sender unit or oil pressure relase stuck hope this helps
Thursday, August 30th, 2007 AT 3:48 PM
