1994 Mitsubishi Mirage Oil Leak at Plugs
Ok, make sure that the oil is coming from the park plug hole, or is it dripping or running down from above the spark plug. Your valve cover gasket may be bad, and if so, they are easily replaced at not too much of cost.
If you have oil coming from your spark plug hole, then your head gasket is blown or you have a cracked head. Both will be a little expensive to repair.
A compression check on all culinders will let you know if you have major problems.[/quote:c8b4277ee4]
Suggested Repair
Confirm whether oil is dripping from above the spark plugs or coming from the plug holes. If it is running down from above, replace the valve cover gasket, which is a relatively inexpensive repair. If oil is coming from the spark plug holes, suspect a blown head gasket or cracked head and perform a compression test on all cylinders before committing to a major repair.
Conversation Summary
The owner of a 1994 Mitsubishi Mirage with 127,000 miles reported oil leaking around the spark plugs on both sides of the engine and hoped to avoid an expensive head-gasket repair. The expert advised confirming whether the oil is dripping from above or coming from the plug holes. A leaking valve cover gasket is a lower-cost possibility, while oil from the plug holes could indicate a blown head gasket or cracked head; a compression test can help identify major problems.
