no spark mitsubishi galant 94 dohc 2.4 liter auto trans.
1994 MITSUBISHI
RLJ7132
  • 5 POSTS
Car stopped and would not start again. Mechanic changed crankshaft sensor and timing belts. Still, engine turns over but no spark. Only way to get irratic spark is by touchig a wire to a wire that goes to the crankshaft sensor and to a ground on body. then, car will try to start and back fire and make a banging noise over and over but will not start. No engine light on and i cannot manually receive any reading from diagnostic connector nder dash by steering wheel and console by using a jumper wire. Could my PCM be bad and what would be the next check?
Feb 23, 2006 at 11:17 AM
RLJ7132
  • 5 POSTS
Believe it or not it still was that crankshaft sensor. A buddy of mines who owns germanos auto in Albany NewYork said to put the dealer crankshaft sensor in there. It cranked right up.
Mar 5, 2006 at 9:50 PM
