1997 Mitsubishi Mirage Won't Start
MITSUBISHI
JOLGREY3343
I have a 1997 Mirage that died on me while driving. I suspect it was out of gas, and refueled. It cranks over and will even sputter a bit, but will not catch to start.
Thanks,
Greg
Oct 28, 2007 at 5:11 PM
BLACKOP555
  • 10,386 POSTS
if your car was ran out of gas then the fuel pump is probably gone. check for fuel pressure at the fuel rail. maybe your car jumped time. put finger over #1 cylinder and crank engine slowly untill you feel a short burst of air and a little bit of suction then see if rotor in distributor is poined at #1 spark plug. if not it jumped time.
Oct 29, 2007 at 1:25 PM
Suggested Repair
Check fuel pressure at the fuel rail, since running out of gas may have damaged the fuel pump. Also verify timing: cover the No. 1 cylinder with a finger, crank slowly until you feel a short burst of air and slight suction, then confirm the distributor rotor points at the No. 1 spark plug. If it does not, the engine may have jumped time.
Conversation Summary
The owner of a 1997 Mitsubishi Mirage says it died while driving, possibly after running out of fuel. After refueling, it cranks and sputters but will not start. The expert recommends checking fuel-rail pressure for a failed fuel pump and verifying distributor timing to determine whether the engine jumped time.
