Low frequency noise from rear of vehicle above 40 mph
1940 MITSUBISHI
KALBRO
I posted this once, but I forgot some information. I have low frequency humming noise for the rear end of the vehicle when I get above 40 MPH. I have a mitsubishi Galant, 1999, 104000miles. 4 cylinder engine. If you have any information that can help narrow down the problem or an idea of what the problem is I would appreciate it.
Jul 18, 2007 at 9:20 AM
MITSUTECH
  • 17 POSTS
first check tires rotate them and see if noise change.if noise did not change then hub bearings should be inspected.
Sep 2, 2007 at 8:39 AM
