Mitsubishi Engine Running Rough
MITSUBISHI
STEVEND135
Hi, I have a question last night some people took my car for a test drive trying to sell it, and it ran fine when they took it but when they brought it back and said it was running rough and it was the timing belt.
I didn't think anything of it then went out later to go to town and started it up and i was running rough while idling and shaking.
Any one know what is wrong with it, could it be the plugs?
thanks
Dec 14, 2006 at 5:49 AM
CARUNDELL
  • 602 POSTS
[quote:8797953356="stevend135"]Hi, I have a question last night some people took my car for a test drive trying to sell it, and it ran fine when they took it but when they brought it back and said it was running rough and it was the timing belt.
thanks[/quote:8797953356]
Hey Steven,
timing belt is certainly a possibility, but check out some simpler things first! Plugs, wire set etc.... will cause the same issue! A quick tune up is the way to go first!
Chris
Dec 14, 2006 at 7:11 AM
Suggested Repair
Check the spark plugs and ignition wires and do a basic tune-up first. A timing belt problem is possible, but simpler ignition issues can cause the same rough idle and shaking.
Conversation Summary
The owner said a Mitsubishi ran fine before a test drive, then returned running rough and shaking at idle. The people who drove it blamed the timing belt. The expert said a timing belt issue is possible but recommended checking the plugs, wires, and doing a tune-up first.
