1996 Mitsubishi Galant Starter Replacement
MITSUBISHI
PRINCEMALIEK
I have a 1996 Galant with 120,000 miles on it. I need to change the starter out. How hard would that be to do in my driveway and do i need to take anything off besides the starter to replace it?
Jul 26, 2006 at 12:58 PM
BESTBET777
  • 89 POSTS
How do you know the starter is bad? you need to check everything in the starting charging circuit att thhe same time, battery, starter, altenator, regulator and replace any bad parts, all at the same time.
Apr 19, 2007 at 6:18 AM
Suggested Repair
Before replacing the starter, test the battery, starter, alternator, and voltage regulator together, then replace any parts that fail.
Conversation Summary
The owner of a 1996 Mitsubishi Galant with 120,000 miles asked how difficult a driveway starter replacement would be and whether anything besides the starter must be removed. The expert did not provide removal steps and instead advised confirming the starter is bad by checking the battery, starter, alternator, and regulator, then replacing any failed parts at the same time.
