1995 Mitsubishi Galant Hard Shifting
MITSUBISHI
NCCHETAN
  • 7 POSTS
Mitsubishi Galant, 1995, 99950 mi
When I started my car this morning I noticed that I couldnt shift into reverse gear easily. I could hear the
gears grind. I hit the clutch and noticed reduced resistance . It easily hits the floor very easily now.
This problem was not there unitl now. I can still drive the car but have to force the gears in place.
Also, I noticed about a week back that when I start the car the idling had gone up. What would generally idle around 1000 rpm was now 1500 rpm. Generally the rpm would rise only when the A/C waas switched on, but since the time the idling has gone up turning the A/C on doesnt seem to make any difference to the rpm. I do not know if this was a precursor to the clutch problem but wanted to furnish this information anyways.
I am a novice when it comes to cars, so I would really appreciate any insight anybody could provide.
Thanks!
Dec 10, 2006 at 8:13 AM
HYKNRD
  • 59 POSTS
I'm not familiar with this car, but it sounds like your clutch is not disengaging.
Most clutches are hydraulically or mechanically operated and are adjustable or not.
It sounds like yours is hydraulic.
If it is you should have a reservoir similiar to your brake fluid reservoir,but smaller.
Check that it's at the proper level.
If low then there's a leak between the reservoir and slave cylinder.
If not your slave cylinder may need adjustment.
Not sure about the idle problem.
Hope that helps. Let us know if it does.
Dec 14, 2006 at 12:34 PM
NCCHETAN
  • 7 POSTS
Thank you very much for your input. I did get it checked out by a mechanic who said the problem was because of air bubbles in the clutch system. It seems to be working fine after he "pumped " them out.
Dec 15, 2006 at 5:53 PM
CARUNDELL
  • 602 POSTS
[quote:b234dbb4bb="ncchetan"]Thank you very much for your input. I did get it checked out by a mechanic who said the problem was because of air bubbles in the clutch system. It seems to be working fine after he "pumped " them out.[/quote:b234dbb4bb]
Hey ncc,
As to your idle issue, it sounds like you may have a minor vacuum leak, try checking all the vacuum hoses on the engine for cracks or breaks. Let me know !
Chris
Dec 15, 2006 at 8:37 PM
Suggested Repair
The hard shifting and soft clutch pedal were caused by air in the hydraulic clutch system; bleeding or pumping the air out restored normal operation. For the higher idle, inspect the engine vacuum hoses for cracks or breaks that could cause a minor vacuum leak.
Conversation Summary
A 1995 Mitsubishi Galant became hard to shift, especially into reverse, with gear grinding and a clutch pedal that dropped to the floor with little resistance. Idle had also risen from about 1000 to 1500 rpm and no longer changed when the A/C was turned on. A reply suggested the clutch was not fully disengaging and advised checking the hydraulic clutch fluid level, looking for a leak, and considering slave-cylinder adjustment. A mechanic later found air in the clutch system and bled it out, after which shifting worked normally. An expert then suggested checking vacuum hoses for cracks or breaks as a possible cause of the high idle.
