HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Mitsubishi
Other
Engine
Symptoms
Revs Up
1992 Other Mitsubishi Models
ANTONNGATA
MEMBER
1992 MITSUBISHI
Engine Mechanical problem
1992 Other Mitsubishi Models 6 cyl Front Wheel Drive Automatic
hi car starts but wont stay running, turns off about three seconds after starting, I can rev it any gear but the same thing happens
Wednesday, October 28th, 2009 AT 10:22 PM
KHLOW2008
MECHANIC
Hi antonngata,
What model and engine do you have?
Is the Check engine light showing?
Thursday, November 5th, 2009 AT 12:23 PM
ANTONNGATA
MEMBER
Its a 3L v3000, engine light only comes on as normal when power is turned on. The engine light never appeared prior to this problem either
Thursday, November 5th, 2009 AT 2:58 PM
KHLOW2008
MECHANIC
What is the model of the vehicle?
Galant, Montero etc?
Friday, November 6th, 2009 AT 6:44 AM
Please
login
or
register
to post a reply.
Related Engine Revs Up Content
1993 Mitsubishi Engine Reves Up And Down
The Engine Was Dropped In With 60k Miles On It, Cant Figure Out Why The Engine Reves Up And Down When Stopped At A Stop Sign, Sometime It...
Asked by
pamsky
1993
MITSUBISHI OTHER
GUIDE
Idle Air Control Motor Replacement
The idle air control motor or idle speed control motor is designed to adjust the air flow into the intake manifold at engine idle. Engine idle speed is monitored by the PCM...
Rpm's Revving
I Have A 1991 Eagle 2000 Gtx 16 Valve Dohc (mitsubishi Engine) Std Transmission & 178,000 Km's. If The Car Is Sitting Idling, The Rpm's...
Asked by
JudyS
1 ANSWER
MITSUBISHI OTHER
Problems At 3000-4000 Rpms
I Have An Eclipse 98 Non-turbo 2.0 L With 87k On It. Usually In The Mornings When I First Start The Car, Or Whenever I Start The Car After...
Asked by
ashkan
1 ANSWER
2012
MITSUBISHI OTHER
Trouble Changing Gears.
Mitsubishi Galant, 1995, 99950 Mi When I Started My Car This Morning I Noticed That I Couldnt Shift Into Reverse Gear Easily. I Could...
Asked by
ncchetan
MITSUBISHI OTHER
1992 Mitsubishi Engine Sometimes Will Not Start
I Have A 1992 3000gt Vr4 That Normally Starts Fine. Sometimes After Parking, It Will Not Start. No Cranking But All Lights And Radio Work....
Asked by
patrickf
1 ANSWER
1992
MITSUBISHI OTHER
VIEW MORE
Vacuum Leak Test and Repair
Vacuum Leak Symptoms
