Installed new battery,,now engine will not idle
how do I reset throttle body position sennsor
Warm the engine to operating temperature and let it idle for an additional 10 minutes so the ECU can relearn idle. Normal driving may also complete the relearn and can take longer than one hour. If the idle still will not stabilize, scan for diagnostic trouble codes.
A 2003 Mitsubishi Eclipse V6 with a manual transmission would not idle after a new battery was installed. The owner asked how to reset the throttle body position sensor. An expert said the idle should relearn through normal driving. After about an hour of driving with no improvement, the expert advised bringing the engine to operating temperature and idling for 10 more minutes, then pulling codes if that does not restore idle. Another user suggested the relearn can take several hours and that moisture may affect the sensor.
