99 Eclipse Damaged Valves/Bad Cylinder Compression
1999 MITSUBISHI
WILLYZ
Hello, I own a 99 Mitsubishi Eclipse RS 2.0 DOHC 5 speed trans with 82,532 miles on it. Recently, I had my Timing Belt and Water Pump replaced. The mechanic put the timing belt back on in the wrong position on the wheel, off by 1 tooth. He drove it up the road and back before discovering it and then had to reposition it. About a month later my #2 spark plug fowled, so I had them do a standard Tune-Up replacing the plugs and what not. Not long after that, my engine light came on and the code came back as insufficient EGR flow or possible vacuum leak I was told. When I had that checked, they did a cylinder compression test because they stated the engine sounded like it was missing. The compression test showed that the #2 cylinder was 75psi, half of what it should be and not even enough to fire the cylinder. The #4 cylinder was also deteriorating at 125psi. They said it is probably a burnt valve. My question is when they replaced my timing belt incorrectly and drove it, could that have damaged my engine and caused all this? Thanx!
Jun 16, 2007 at 4:41 AM
JAVA MOTORSPORTS
  • 52 POSTS
If it only was one tooth out of time then no it would not have caused this. It would have bent the valves and may have knocked a hole the the pistons. Was the car running good before all the work was done? If so it could have bent the valve.
Jun 18, 2007 at 4:53 AM
