1996 Other Mitsubishi Models LOTS OF CLEAR WATER FROM EXHAUS
1996 MITSUBISHI
WILLIAM ZHANG
  • 12 POSTS
Other Category problem
1996 Other Mitsubishi Models 4 cyl Wheel Drive Type unknown Automatic 110000 miles
1996 Mistibishi Maga, 2.4L, auto, 110,000km
some clear water continously dripping from tail pipe while drving for quite some time . No somking, no odor.the engineer sounds ok.
Thanks
Jan 7, 2008 at 7:46 AM
BMRFIXIT
  • 19,053 POSTS
[quote:b7ae29a4cd="william zhang"]Other Category problem
Thanks[/quote:b7ae29a4cd]
Its called condensation
if you dont have any fluid leak or lose
you should be fine and dont worry about it
it common and normal
Jan 7, 2008 at 8:24 AM
WILLIAM ZHANG
  • 12 POSTS
Apprecaited!
but not a little clear water. quite some and continuously coming out from exhaust pipe while drving with our A/C.
Thanks
Jan 7, 2008 at 8:32 AM
BMRFIXIT
  • 19,053 POSTS
again if all your fluids OK car running fine
weather will effect the amount of the condensation
also some after market muflers and exhaust system may don’t have a drain hole in it or it became clogged
Water is a by-product of the combustion process, you will produce almost 1litre of water per liter of fuel used, now this is most evident when the engine is cold, water dripping from the exhaust and stem as it is heating up, when the engine and exhaust is fully hot, this water vapor is not visible , if water or vapor is still visible after warm up, it may be that the engine is running to cold, or there is a problem somewhere, If coolant levels are constant and no white smoke that is normally the anti freeze agent burning off, I would not be overly concerned, but for piece of mind maybe get your work shop to inspect things for you.
Jan 7, 2008 at 9:14 AM
