1999 Other Mitsubishi Models Wheel Studs
1999 MITSUBISHI
METALLICA312869
  • 5 POSTS
Tires and Wheels problem
1999 Other Mitsubishi Models 4 cyl Two Wheel Drive Automatic 135ish miles
well, when i bought this car it only had three wheel studs on the front left tire. i drove it this way for roughly 9 months before it started to cause me any problems. now, it is broke down in my drive, with another broken stud and one of them stripped. the one that is stripped, isnt stripped on the threads. the teeth on the back of it that hold it into the hub are stripped. i backed the lug nut about half way off before it wouldnt move anymore and just spun with the wheel stud. i have tried justabout everything i can think of the break the stripped stud, however nothing has worked. if anyone has any ideas or knows how to fix this problem please reply asap.
Nov 27, 2008 at 6:13 AM
  • 31,937 POSTS
Hi there ,
You will have to get an angle grinder to cut the stud in half, you can hire them cheaply, and always use safety glasses as well.
Mark (mhpautos)
Nov 27, 2008 at 6:59 AM
METALLICA312869
  • 5 POSTS
i cant get to the stud to cut it with a grinder. there is a shield on the back and i cant get to the bolt on the front either
Nov 27, 2008 at 7:04 AM
  • 31,937 POSTS
Use a pair of locking plyers and hold the stud, try and locate the plyers so the stud cant turn, drill the stud it starting with a small drill first and working your way up till it is able to be struck with a chisel to sheer it off easily.
Mark (mhpautos)
Nov 27, 2008 at 7:12 AM
METALLICA312869
  • 5 POSTS
Thank you mark. what size bit should i use to start out with? like 1/8th inch?
Nov 27, 2008 at 7:17 AM
  • 31,937 POSTS
Hi there,
Yes that should be OK, make sure that you center the drill carefully, use new bits and work your way up in small increments, get some spray on drill lube so you don't burn out the drill bits .
mark (mhpautos)
Nov 27, 2008 at 7:25 AM
METALLICA312869
  • 5 POSTS
i have pb blaster and wd 40 as lubricants which should i use
Nov 27, 2008 at 7:28 AM
  • 31,937 POSTS
The WD 40 will be fine,
Nov 27, 2008 at 8:04 AM
METALLICA312869
  • 5 POSTS
thanks for the help
Nov 27, 2008 at 11:02 AM
