1995 Other Mitsubishi Models White Smoke
1995 MITSUBISHI
156,000 MILES • 6 CYL • FWD • MANUAL
MREYNA
Okay so my 3000gt is blowing white smoke from the tail pipe, usually it does it after the car is warm, and the only time I see it is when the car is at a stop. It is very continuous and it has almost overheated several times. I check the coolant and it seems to be boiling so I wait for it to cool then start driving again, but I've always been cautious not to let it get in the red. I dont see any fluid leakage on my driveway so I'm not sure what this could mean. It does although burn oil so I have to check it once a week, but I just figured that it was because the car was so old. Please advise. Thanks!
Mari
Aug 19, 2008 at 2:04 PM
  • 31,937 POSTS
Hi there,
White smoke is a sign of coolant in the combustion chamber, i would be getting a head check done for exhaust gasses in the cooling system, start here.
mark (mhpautos)
Aug 19, 2008 at 6:44 PM
  • 31,937 POSTS
Hi there,
You can get a head check done, this will check for any exhaust gasses in the cooling system, this is a sure sign that you have a problem with the cylinder head or gasket, check the link at the bottom of this reply for your work shop manual requirements.
Mark (mhpautos)
Aug 24, 2008 at 11:11 AM
