1995 Other Mitsubishi Models timing belt
1995 MITSUBISHI
158,000 MILES • 4 CYL • FWD • AUTOMATIC
MAMA_C_TAAA
i recenlty bought a 1995 mitsubishi mirage ls for VERY cheap and it will need a new timing belt. i'm unsure about how to replace them. can you please help me with this?[img:e2de846b16]http://www.2carpros.com/forum/automotive_pictures/142203_01150201040901030320080108d697a0f4889ef3f4a5008540_1.jpg[/img:e2de846b16]
Jan 12, 2008 at 7:35 AM
MERLIN2021
  • 17,250 POSTS
I will tell you if the belt is broke already, it could need a lot more than the belt! If you havnt done one of these, it's not for the occasional fix it guy. If your belt is still intact, have a mechanic replace it. If you are determined to give it a go, check the link at the bottom of my answer, you will need the manual to try to do it right!
Jan 12, 2008 at 8:35 AM
MAMA_C_TAAA
how does it work when you put it on? do you have to set it?
Jan 12, 2008 at 8:56 AM
