1992 Other Mitsubishi Models Question Regarding On Board Dia
SRWINES
MEMBER
1992 MITSUBISHI
4 CYL
2WD
MANUAL
112,000 MILES
Check engine light was on and was not idling properly when it is first cranked. Took it to local repair shop--they said it was a bad computer (ECU). I was able to open the computer unit and change bad capacitors. It still having the same problem.
How do I operate on board diagnosis and where is it located on the car?
Any other suggestions?
SPONSORED LINKS
Saturday, June 28th, 2008 AT 2:20 PM
KHLOW2008
MECHANIC
Hi srwines,
If it is 12 pin socket found attached to side of driver side fuse box.
Bridge terminal 1 and 12 to get blinking from checklight.
If OBD II type diagnostic socket, bridge terminal 1 and 4.
