I was jumping another vehicle and crossed battery and ground momentarily. Since then, the rpms raise and lower as I accelerate and the check engine light comes on. The trouble code reads Idle control motor sensor or throttle control sensor or harness problems.
I tested all the functions and harnesses and every thing seems to be woking properly.
I can sometimes drive as much as 5 miles with no problem, then, it starts pulsatng and the check engine light comes on again with the same code.
Does any one have any ideas?
Thank you!
Tuesday, December 30th, 2008 AT 6:38 PM
