2001 Mitsubishi Montero Leak
2001 MITSUBISHI MONTERO
170,000 MILES • 6 CYL • 2WD • AUTOMATIC
ANDYGOSWICK
I have a leak that it seems to be between my valve covers and block: That would be a head gasket I assume? It's not a huge leak but is there anything I can do to slow it down temp. until we get the money to fix it? I just had the valve covers, a tune up, new tires and new catalytic converter installed as well as AC Compressor. I really don't want to spend any more money..
Andy
May 14, 2010 at 3:14 AM
  • 31,937 POSTS
Hi there,
If you try and re tension the head you will cause more problems , same with adding any stop leak muck, best leave until you can do the job correctly.
mark (mhpautos)
May 15, 2010 at 11:56 PM
