Engine Performance problem
1992 Mitsubishi Montero 6 cyl Four Wheel Drive Automatic
I had white smoke after engine warmed up so I inspected heads so I got different heads had machine shop check them resurface new head gasket they did check for cracks as these were used heads. Put it back together and I still have the same white smoke after engine warms up and Ideas, Is this a cracked block?
Oct 5, 2008 at 10:27 AM
