1997 Mitsubishi Mirage car won't start
CHARLESSA
  • 1997 MITSUBISHI MIRAGE
Engine Mechanical problem
1997 Mitsubishi Mirage Automatic 187000 miles
My 1997 Mitsubishi Mirage started to get real hot sometimes while driving but mostly when I was stuck in a drive-thru pressing the brakes down and the car not moving. While on the highway the car started to smoke and after pulling over the car completely shut down but seemed as if it wants to crank but it's still not. This one mechanic stated that my timing belt needed to be replaced so that my valves or something can open. It's not the head gaskets because there was no water in the oil from what I was told. What can be the problem? Is it the timing belt
Saturday, July 25th, 2009 AT 10:59 AM
  • 110,182 POSTS
Overheating can cause many things. It can cause a headgasket to go (without leaking coolant into the oil), it can warp an engine block or head, but it would be unusual for it to break a timing belt. Before doing anything, I would recommend checking engine compression. Here is a how to:
https://www.2carpros.com/dia/how_to_check_compression.htm
Let me know what the compression in each cylender is.
Saturday, August 8th, 2009 AT 9:10 PM
