It could just be from a loss of power. The a/c does put some stress on the engine. Do you believe the car to be suffering from a loss of power? Here are some things to look at, number 7 is not it. You do not want to throw too much money at a car unless you know the prblem, but most of these are cheap and need to be done often anyway Engine lacks power. See one of the following: 1.) Incorrect ignition timing. 2) Fuel filter clogged and/of impurities in fuel 3) Faulty or incorrect gapped spark plugs. 4) Air filter dirty. 5) Spark timing control system not working properly. 6) Faulty ignition coil(s) 7) Brakes binding. 8) Auto Trans fluid not correct 9) faulty distributor cap or wires 10) EGR system not functioning properly. 11) Use of sub standard fuel. 12) Low or uneven cylinder compression pressures 13) Air vacuum leak at intake manifold or plenum. Remember that not all of this applies, but smoe could
Thursday, January 22nd, 2009 AT 5:17 AM
