2006 Mitsubishi Galant
2006 MITSUBISHI GALANT
65,000 MILES • 4 CYL • FWD • AUTOMATIC
MOORED194
When I hit the gas in my 2006 Galant (4cyl) it makes a very bad rattling sound. It sounds almost like a tin can is being dragged down the street. It used to only be when you accelorated slowly but the sound has now progressed to when it's idleing as well. Any Ideas on what this could be. There is no change in the overall performance of the car it almost seems like there is a loose piece of metal under the car tapping on the exhaust.
Oct 21, 2008 at 2:09 PM
TECHNOPRO
  • 45 POSTS
Can you listen on which side is the noise coming from? Transmission area, engine area or down exaust?
Could be something down the exaut pipe? let mo know how you get on.
Oct 24, 2008 at 3:17 AM
MOORED194
It sounds like it's coming from under the engine on the passenger side of the car. I thought it almost sounded like the heat sheild is coming loose?
Oct 24, 2008 at 7:01 AM
TECHNOPRO
  • 45 POSTS
I would check if the shields are not loose or something stuck in between the shield and the exaust pipe itself. Very common here in New Zealand as the stone chips on the roads keep flying!!
Be careful of the heat off the pipe as you can easily burn yourself.
Ideally it would be a good idea to put the car on a pit or hoist...if not try to put the car on wooden blocks so that you can get easy access underneath. Good luck and keep me updated.
Oct 26, 2008 at 4:47 AM
SABELEV
I have Galant 2006 2.4L with 53K miles with same rattle noise problem. I would like to know what does cause to this noise.
Nov 19, 2008 at 8:37 AM
TECHNOPRO
  • 45 POSTS
Do the same procedures as describe above and see what you come up with and let us know your findings.
Cheers
Nov 21, 2008 at 3:25 AM
DRIGGS1533
I had this same noise over the summer, I took it to the dealer and found that it was my heat shield, and there was a safety recall on this part. I would advise just to take it to the dealer and have them check the car for any recalls.
Jan 5, 2009 at 7:39 AM
