2000 Mitsubishi Galant engine problems
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
ZHIQUAN
I have three problems with my car engine:
1. oil leakage.
2. missfire for #3 cyl (P0303)
3. manifold differential pressure sensor circuit malfunction (P1400)
I was told to replace: calve cover gasket, upper intake gasket, spark plugs, plug wires. And the total cost is 500$, including labors.
I am wondering if I do some by myself. Are all there problems serious and need to be fixed immediately? What would be the consequece if I delay them.
Thanks.
Mar 26, 2010 at 1:05 PM
LEGITIMATE007
  • 5,121 POSTS
if you delay them for a couple of weeks to a month ,there should be no problem, if these are actually the problems of your vehicle. you can always replace your own wires, just do them one at a time. mapp sensor should be hard for you to replace, thats another name for the manifold sensor.
Apr 4, 2010 at 6:59 AM
